Gotowe. Wszystko działa i hula.
Gdyby ktos miał ochotę zbudowac sobie radyjko do odbioru "Radia Nowy Świat" to proszę bardzo:
20210222_124806.jpg [ 2.76 MiB | Przeglądane 6022 razy ]
KOD:
// Audio output : GND and RX
// I2C connection LCD 16x2: D2 - SDA D1 - SLC
// Processor speed 160Mhz
#include <Arduino.h>
#ifdef ESP32
#include <WiFi.h>
#include <HTTPClient.h>
#else
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#endif
#include <WiFiManager.h> //
https://github.com/tzapu/WiFiManager#include "AudioFileSourceICYStream.h"
#include "AudioFileSourceBuffer.h"
#include "AudioGeneratorMP3.h"
#include "AudioOutputI2SNoDAC.h"
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
//#include <EEPROM.h>
WiFiServer server(80);
LiquidCrystal_I2C lcd(0x27, 16, 2);
char URL[100]="http://n04a-eu.rcs.revma.com/ypqt40u0x1zuv";
char url[100];
AudioGeneratorMP3 *mp3;
AudioFileSourceICYStream *file;
AudioFileSourceBuffer *buff;
AudioOutputI2SNoDAC *out;
void setup(){
// EEPROM.begin(512);
Serial.begin(115200);
// initialize the LCD
lcd.begin();
lcd.setCursor(0,0);
lcd.print("Radio Nowy Swiat");
delay(1000);
Serial.println("Connecting to WiFi");
lcd.clear();
lcd.print("Connecting WiFi");
delay(1000);
lcd.clear();
lcd.print("AutoConnectAP");
lcd.setCursor(0,1);
lcd.print ("//192.168.4.1/");
delay (500);
WiFiManager wifiManager;
// Uncomment and run it once, if you want to erase all the stored information
//wifiManager.resetSettings();
wifiManager.autoConnect("AutoConnectAP");
lcd.setCursor(0,1);
lcd.print("Connected");
Serial.print("Connected");
lcd.clear();
delay(1000);
//------------------REDIRECT PROCEDURE-------------------------
const char* headerNames[] = { "Location" };
String Location;
int pos1, pos2;
HTTPClient http; //HTTP OPENING
http.begin(URL); //HTTP Connecting
http.collectHeaders(headerNames, sizeof(headerNames)/sizeof(headerNames[0]));
Serial.println("headerNames "); Serial.print(headerNames[0]);
Serial.print("headerNames 0 ");Serial.print(headerNames[0]);
// Serial.print sizeof(headerNames[0]);
int httpCode = http.GET(); // Get error code
Serial.print(httpCode);
//------- follow redirect -----------
if (httpCode == 302) // Its mean - stream is redirect
lcd.setCursor (0,0);
lcd.print(" Following");
lcd.setCursor (0,1);
lcd.print(" redirect");
Serial.println("Location");
Location = http.header("Location");// New stream adress
Serial.println(Location);
else
Location = URL;
http.end();
//----------------STRING TO CHAR------------------------
Location.substring(0, Location.length()+1).toCharArray(url, Location.length()+1);
//-------------------Connectin to stream---------------------------
file = new AudioFileSourceICYStream(url);
file->RegisterMetadataCB(MDCallback, (void*)"ICY");
buff = new AudioFileSourceBuffer(file, 4096);
buff->RegisterStatusCB(StatusCallback, (void*)"buffer");
out = new AudioOutputI2SNoDAC();
mp3 = new AudioGeneratorMP3();
mp3->RegisterStatusCB(StatusCallback, (void*)"mp3");
mp3->begin(buff, out);
lcd.clear(); // Clear any comments from LCD
void loop()
static int lastms = 0;
if (mp3->isRunning()) {
if (millis()-lastms > 400) { // Every 350 ms Scroling display.
lastms = millis();
lcd.scrollDisplayLeft();
// Serial.printf("Running for %d ms...\n", lastms);
Serial.flush();
if (!mp3->loop()) mp3->stop();
} else {
Serial.printf("MP3 done\n");
lcd.print ("RECONNECTION");
delay(1000);
ESP.restart();
// Called when a metadata event occurs (i.e. an ID3 tag, an ICY block, etc.
void MDCallback(void *cbData, const char *type, bool isUnicode, const char *string)
const char *ptr = reinterpret_cast<const char *>(cbData);
(void) isUnicode; // Punt this ball for now
// Note that the type and string may be in PROGMEM, so copy them to RAM for printf
// char s1[32], s2[64];
// strncpy_P(s1, type, sizeof(s1));
// s1[sizeof(s1)-1]=0;
// strncpy_P(s2, string, sizeof(s2));
// s2[sizeof(s2)-1]=0;
// Serial.printf("METADATA(%s) '%s' = '%s'\n", ptr, s1, s2);
String mystring(string);
mystring.replace("ę", "e");mystring.replace("ó", "o");
mystring.replace("ą", "a");mystring.replace("Ś", "S");
mystring.replace("ś", "s");mystring.replace("Ł", "L");
mystring.replace("ł", "l");mystring.replace("Ż", "Z");
mystring.replace("Ź", "Z");mystring.replace("Ć", "C");
mystring.replace("ń", "n");mystring.replace("ć", "c");
mystring.replace("ź", "z");mystring.replace("ż", "z");
lcd.setCursor(0,1);lcd.print(mystring);
lcd.setCursor(0,0);lcd.print(" Radio Nowy Swiat Radio Nowy Swiat ");
Serial.flush();
// Called when there's a warning or error (like a buffer underflow or decode hiccup)
void StatusCallback(void *cbData, int code, const char *string)
// Note that the string may be in PROGMEM, so copy it to RAM for printf
char s1[64];
strncpy_P(s1, string, sizeof(s1));
s1[sizeof(s1)-1]=0;
Serial.printf("STATUS(%s) '%d' = '%s'\n", ptr, code, s1);
Serial.flush();
//-------------------------------------------KONIEC-------------------
Elementy skladowe:
Platforma ESP32 , ja zastosowałem Lolin Node mcu V3 za 20 zł, do tego wyswietlacz za 20 złotych i kowerter SPI do wyswietlacza za 10 zł do tego wtyczka do głosników komputerowych i już.
Kod jest rozwinieciem przykladu "Simple Web Radio" Earle F. Philhowera, dołączone do biblioteki ESP8266 Audio, tegoz autora.
Dodałem i zmieniłem:
-Sposób połączenia z WiFi, przy braku zapisanej sieci otwiera serwer i przez strone internetową mozna zalogopwać się do sieci.
-Przekierowanie strumienia stacji, bo w wersji początkowej odbierało tylko stały adres streamingu.
- Obsługe wyswietlacza LCD 16x2 po magistarli ISP.
Schemat za chwilę jak ogarne bałagan na komputerze.
Schemat nie potrzebny.
Wszystko opisane w kodzie.
Materiały
LOLIN nODEMCU V3
Wyswietlacz LCD 16x2
I2c do wyswietlacza
Gniazdo słuchawkowe.
Wszytko dostepne na ABC-RC.
Pierwsze uruchomienie:
Wchodzimy komputerem do sieci WiFi które generuje radio AutoConnectAP, potem na 192.168.4.1 i wskazujemy sieć i hasło do WiFi. Potem juz loguje sie sam.
