Teraz jest wtorek, 24 listopada 2026, 11:39
 Tytuł: WD-40 ciekawe informacje -po angielsku niestety
PostNapisane: piątek, 9 kwietnia 2010, 23:17
Skopiowalem z tutejszego forum - historia prawdziwa :)
Before you read to the end, do you know what the main ingredient of WD-40 is?
I had a neighbour who had bought a new van. I got up very early one Sunday morning and saw that some vandal had spray painted red all around the sides of this white van. I went over and told him the bad news.
He was very upset and was trying to work out what to do, probably nothing until Monday morning, since nothing was open.
Another neighbour came out and told him to get some WD-40 and clean it off. It removed the unwanted paint beautifully and did not harm the paint that was on the van. I'm impressed!
WD-40 - how did someone work out it would do that?
'Water Displacement No.40'.
The product began from a search for rust preventative solvent and degreaser to protect missile parts. WD-40 was created in 1953 by three technicians at the San Diego Rocket Chemical Company. Its name comes from the project that was to find a 'water displacement' compound.
They were successful with the fortieth formulation, thus WD-40. The Convair Company bought it in bulk to protect their Atlas missile parts.
Ken East (one of the original founders) says there is nothing in WD-40 that would hurt you. It's the first thing that has ever cleaned that spotty shower screen. If yours is plastic, it works just as well as on glass. It's a miracle!
Then try it on your cooker top . . . . it's now shinier than it's ever been. You'll be amazed!
Here are some other uses:
1. Protects silver from tarnishing.
2. Removes road tar and grime from cars.
3. Cleans and lubricates guitar 20 strings.
4. Gives floors that 'just-waxed' sheen without making them slippery.
5. Keeps flies off cows. (The cows don’t like the smell though!)
6. Restores and cleans blackboards.
7. Removes lipstick stains.
8. Loosens stubborn zips.
9. Untangles jewellery chains.
10. Removes stains from stainless steel sinks.
11. Removes dirt and grime from the barbecue grill.
12. Keeps ceramic/terra cotta garden pots from oxidizing.
13. Removes tomato stains from clothing.
14. Keeps glass shower screens free of water spots.
15. Camouflages scratches in ceramic and marble floors.
16. It keeps scissors working smoothly.
17. Lubricates noisy door hinges on vehicles and doors in homes.
18. It removes black scuff marks from the kitchen floor! Use WD-40 for those nasty tar and scuff marks on flooring. It doesn't seem to harm the finish and you won't have to scrub nearly as hard to get them off. Just
remember to open some windows if you have a lot of marks.
19. Dead insects will eat away the finish on your car if not removed quickly! Use WD-40!
20. Gives a children's playground slide a shine for a super fast slide.
21. WD-40 is great for removing crayon from walls. Spray on the mark and wipe with a clean rag.
22. Also, if you've discovered that your teenage daughter has washed and dried a tube of lipstick with a load of laundry, saturate the lipstick spots with WD-40 and rewash. Hey Presto! The lipstick is gone!
23. Lubricates tracks in sticking home windows and makes them easier to open.
24. Spraying an umbrella stem makes it easier to open and close.
25. Restores and cleans padded leather dashboards in vehicles, as well as vinyl bumpers.
26. Restores and cleans roof racks on vehicles.
27. Lubricates and stops squeaks in electric fans.
28. Lubricates wheel sprockets on tricycles, wagons, and bicycles for easy handling.
29. Lubricates fan belts on washers and dryers and keeps them running smoothly.
30. Keeps rust from forming on saws and saw blades, and other tools.
31. Removes splattered grease on stove.
32. Keeps bathroom mirror from fogging.
33. Lubricates prosthetic limbs.
34. Keeps pigeons off the balcony (they hate the smell).
35. Removes all traces of duct tape.
36. Folks even spray it on their arms, hands, and knees to relieve arthritis pain.
37. WD-40 attracts fish. Spray a little on live bait or lures and you will be catching the big one in no time. Also, it's a lot cheaper than the chemical attractants that are made for just that purpose.
38. Use it for gnat bites. It takes the sting away immediately and stops the itch.
And for some reason...........spray it on your arthritic knee joints etc., and it will ease them.
PS. The basic ingredient is FISH OIL! Laughing
 Tytuł: Re: WD-40 ciekawe informacje -po angielsku niestety
PostNapisane: sobota, 10 kwietnia 2010, 02:51
WD to wielki niewypał do tego strasznie agresywny dla wielu tworzyw sztucznych
PostNapisane: sobota, 10 kwietnia 2010, 07:13
Co do opinii o WD - w pełni potwierdzam. Używam wynalazku o nazwie TRI-FLOW. Rewelacyjny środek z dodatkiem teflonu, z racji właściwości smarujących i niskiej przyczepności kurzu i zanieczyszczeń po jego użyciu. Nie jest agresywny dla tworzyw sztucznych na 100%.
TRI FLOW
i jeszcze trochę informacji
Sebastian
Ostatnio edytowano sobota, 10 kwietnia 2010, 07:21 przez El-Diablo, łącznie edytowano 1 raz
PostNapisane: sobota, 10 kwietnia 2010, 07:19
Sebastian masz jakiegoś linka do opisu? Byłbym wdzięczny .Szczególnie interesują mnie pełne karty katalogowe
PostNapisane: sobota, 10 kwietnia 2010, 07:31
Krzysiek pisaliśmy w tym samym czasie. Niestety nie wiem gdzie można namierzyć Kartę katalogową.
Tak czy inaczej głównie poza modelarstwem używam tego przy maszynach o dużym zapyleniu (stolarstwo), nie znalazłem jeszcze lepszego środka, ba nie mam zamiaru szukać - ten jest naprawdę rewelacja.
Sebastian
PostNapisane: sobota, 10 kwietnia 2010, 07:44
Moje pytanie ma obawy finansowe i nie jest zaczepką - to celem wyjaśnienia .
Był czas gdy plastikowe prowadnice w maszynie wszyscy smarowali WD bo niby do wszystkiego .
po kilku tygodniach prowadnice skruszały i popękały.
Gdy zakupiłem WD w kanistrach po 25 litrów dopiero przeczytałem pełną kartę i jest tam wyraźne ostrzeżenie przed ryzykiem stosowania na tw sztucznych . Szkoda ze nie było go na opakowaniach detalicznych
PostNapisane: sobota, 10 kwietnia 2010, 07:49
Ależ spoko nie odebrałem tego jako zaczepkę. Powiem tak, w okleiniarkach których używam posuw elementów odbywa się na gąsienicach częściowo wykonanych z tworzywa. Nie ma najmniejszych oznak zużycia, czy też zmian mechanicznych.
Skontaktuj się firmą w której zakupuję ten smar - Firma RATO, ul. Dolna 2B , 84-230 Rumia - e-mail: biuro@rato.pl.
Sądzę że bez problemu prześlą Ci potrzebne informacje.
Sebastian
PostNapisane: sobota, 10 kwietnia 2010, 08:19
Ja WD używam głównie do poluzowania jakiś zardzewiałych śrub, ewentualnie do zamka, zawiasów w drzwiach by lepiej chodziły :)
Pozdrawiam, Sebastian!
PostNapisane: sobota, 10 kwietnia 2010, 08:35
Bo jak coś jest do wszystkiego to jest do .......A tak na poważnie chłopcy od Wuja Sama opracowali ten środek do konserwacji i mycia części i tak jest tam używany a nie jako smar do smarowania.
Wojtek
PostNapisane: niedziela, 11 kwietnia 2010, 13:28
Dokladnie tak - WD sluzy do usuwania smarow, a nie smarowania :)
Ale trzeba przyznac, ze wlasciwosci czyszczace ma rewelacyjne ...
PostNapisane: sobota, 5 czerwca 2010, 22:21
Dołączył(a): sobota, 3 kwietnia 2010, 15:39
Jeśli potrzebna będzie translacja na PL dla kogoś proszę dać znać.
"Homo sum; humani nihil a me alienum puto."
Tomasz
PostNapisane: sobota, 5 czerwca 2010, 23:03
to wpiszę sobie translate online PL-EN w google ;)
PostNapisane: niedziela, 6 czerwca 2010, 12:27
Chciałem się przysłużyć z racji wykształcenia tłumaczeń google ja nie uznaje. Mimo wszystko pozdrawiam serdecznie.
Tomasz
PostNapisane: niedziela, 6 czerwca 2010, 12:35
A tlumacz - co Ci bedziemy zabraniac :)
Jak Ci sie chce to moge wiecej tekstow wrzucac - z niektorymi bedziesz mial naprawde zagwozdke (latwo zrozumiec, ale przetlumaczyc :D )
PostNapisane: niedziela, 6 czerwca 2010, 13:32
To tłumaczymy:) P.S. Jeśli będziesz miał zagwozdki z czymś napisz na PW nie mam zbytnio czasu na regularne odwiedziny ale chętnie pomogę:)
Zanim przeczytasz do końca, czy wiesz jaki jest główny składnik WD-40?
Mój sąsiad kupił nowego vana. Gdy obudziłem się w sobotę rano zobaczyłem iż jakiś wandal pomazał czerwonym sprayem boku jego furgonetki.
Wtedy poszedłem do niego by przekazać mu złe wieści. Zdenerwowało go to po czym spróbował wymyślić co zrobić dalej (najprawdopodobnij nić do poniedziałku, ponieważ wszystko było zamknięte).
Wtedy zjawił się kolejny sąsiad i powiedział że wyczyści boki auta przy pomocy WD-40. Usunął niechcianą farbę nie niszcząc powierzchni lakierniczych na aucie. Byłem pod wrażeniem.
WD-40 - jak dojść do zasady jego działania?
'Wypieracz Wodny No.40'.
Produkt powstał w wyniku poszukiwania odrdzewiacza i degragatora dla ochrony części pocisków. WD-40 został stworzony w 1953 roku przez trzech techników San Diego Rocket Chemical Company. Jego nazwa pochodzi od projektu, którego celem było rozpraszanie wody.
Jako iż produkt zadziałał jego nazwa została skrócona do WD-40. Firma Convair zakupiła pełną paczkę by chronić przy jej pomocy części rakiet typu Atlas
Ken East jeden z twórców, twierdzi iż WD-40 nie znajdują się żadne substancje mogące zaszkodzić człowiekowi. "To jest pierwsza rzecz, która wyczyści zabrudzoną kabinę prysznicowa. Jeśli twoja jest z plastiku również sobie z nią poradzi. To cud.
Gdy wypróbujesz go na płycie kuchenki... okaże się iż jest tka czysta jak nigdy. Będziesz zaskoczony!"
Inne zastosowania:
1. Chroni srebro przed matowieniem.
2. Usuwa smołę i brud z aut.
3. Czyści i nawilża struny gitarowe.
4. Nadaje woskowy sznyt podłogą bez czynienia ich śliskimi.
5. Odstrasza muchy od krów. (Choć krowy też nie przepadają za tym zapachem!)
6. Odnawia i czyści tablice.
7. Usuwa ślady szminki.
8. Luzuje zacinające się zamki błyskawiczne.
9. Rozplątuje splątaną biżuterie.
10. Usuwa plamy z zlewów z stali nierdzewnej.
11. Usuwa bród i smoliste nacieki z grilla.
12. Zapobiega oksydowaniu ceramicznych i terakotowych doniczek ogrodowych.
13. Usuwa plamy z pomidorów z ubrań.
14. Zapobiega pojawianiu się plam wodnych na szklanych powierzchniach kabiny prysznicowej.
15. Ukrywa zadrapania w podłogach ceramicznych i marmurowych.
16. Sprawia, że nożyczki działają płynnie.
17. Nawilża hałaśliwe zawiasy w drzwiach domów i aut.
18. Usuwa czarne ślady od obuwia z podłogi kuchennej! Używaj WD-40 do usuwania tych okropnych śladów błota i innych zabrudzeń z podłóg. Nie powoduje dodatkowych uszkodzeń do ich wykończeń i nie wymaga tak silnego szirowania. Pamiętaj by otworzyć okna jeśli trzeba usunąć wiele śladów i zabrudzeń.
19. Martwe insekty mogą zniszczyć powłokę lakierniczą Twojego auta jeśli szybko ich nie usuniesz. Użyj WD-40!
20. Nadaje zjeżdzalni na placu zabaw połysk umożliwiający szybki zjazd.
21. WD-40 świetnie radzi sobie z śladami kredek na ścianach. Nałóż na ślad i przetrzyj czystą szmatką.
22. Jeśli dostrzeżesz iż Twoja nastoletnia córka zrobiła pranie z użyciem szminki natryskując na jej ślady WD-40 i wypierz raz jeszcze. Gotowe! Szminka znikła!
23. Smaruje prowadnice zacinających się okien domowych ułatwiając ich otwarcie.
24. Natrysk na ruchome części parasola ułatwia jego otwarcie.
25. Odnawia i oczyszcza winylowe jak i skórzane elementy auta.
26. Odnawia i oczyszcza relingi dachowe w autach.
27. Smaruje i wycisza wiatraki.
28. Smaruje szprychy w rowerach wózkach i motocyklach dla lepszego prowadzenia.
29. Smaruje pasy napędowe pralek i suszarek usprawniając ich prace.
30. Zatrzymuje proces rdzewienia na piłach ich ostrzach jak i innych narzędziach.
31. Usuwa rozchlapany tłuszcz ze stołków.
32. Zapobiega zamgleniu łazienkowego lustra.
33. Smaruje sztuczne kończyny.
34. Odstrasza gołębie od balkonu (nienawidzą tego zapachu).
35. Usuwa ślady taśmy klejącej.
36. Ludzie potrafią nawet natryskiwać WD-40 swoje ramiona, dłonie i kolana by uleżeć bulą artretycznym..
37. WD-40 przyciąga ryby. Natryśnij niewielką ilość na żywą przynętę a złapiesz dużą sztukę w mgnieniu oka. Jest również tańsza od chemicznych zanęt wymyślonych w tym jednym celu.
38. Uzywaj także po ukąszeniu komara. Powoduje zanik śladu ukąszenia jak i swędzenia.
P.S. Podstawowym składnikiem jest olej rybny! Ha Ha Ha
Tomasz
PostNapisane: niedziela, 6 czerwca 2010, 17:59
sprawdzę tą teorię - jak nic nie złowię to się zemszczę na producencie..
a może wd działa tylko w brudnej tamizie?
PostNapisane: niedziela, 6 czerwca 2010, 18:19
do kompletu powinna mieć jeszcze działanie podobne do zielonych tabsów :) a wtedy WD jest w pełni uniwerslane i powinno być sprzedawane jako niezbędnik survivalisty.
PostNapisane: niedziela, 6 czerwca 2010, 19:06
No i Bondowi się zapewne przyda :mrgreen:
Sebastian
PostNapisane: poniedziałek, 7 czerwca 2010, 08:44
...czyli jak ruski kombajn: goli, p... e, tego, ciupcia i usuwa ciążę...
PostNapisane: wtorek, 22 czerwca 2010, 07:56
Oświadczam - teoria została brutalnie sprawdzona.
Dziś będąc z córą na rybach na bardzo rybnym łowisku podkusiło mnie by sprawdzić działanie WD-40
Faktycznie działa .
Spryskałem tym robaki i przez następne 3 godziny już nie mieliśmy żadnego kontaktu z rybą!
Skuteczny odstraszacz!
Ciekawe czy na komary tez działa - tego nie mogłem sprawdzić bo rano była mgła i żadne gryzące nie latały
PostNapisane: wtorek, 22 czerwca 2010, 09:11
Faktycznie działa .
Krzysiu, co ja Ci będę dużo gadać - po prostu się nie znasz - ZA MAŁO ŚRODKA DAŁEŚ na robaka! :mrgreen:
Sebastian
PostNapisane: wtorek, 22 czerwca 2010, 11:47
Ty wiesz jaką plamę tym wywołałem... a psiknąłem tak z umiarem.
Kolejny przykład że w reklamie wolno wszystko
PostNapisane: wtorek, 22 czerwca 2010, 12:02
Niewłaściwe ryby łowiłeś. Skoro olej rybny, to pewnie tylko na drapieżniki działa :D
PostNapisane: wtorek, 22 czerwca 2010, 12:04
Sztuczka polega na tym aby wlac kilkaset litrow wd do wody i ryby po prostu wytruc lol
141,158,154 Wyświetlone Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
